rtate's avatar
rtate
Axle Alignment
Both tires on the door side of my trailer are showing are showing quite a bit of wear on the outside two inches. The tires on the other side are wearing perfectly.
I have one small slide on the door side and one large slide and small bedroom slide on the other side. So the off door side is carrying much more of the weight.
Is it possible that the weight distribution is causing the uneven tire wear and what can I do to correct it?
