I just edited my op. I had left off part of a sentence. Maybe it makes more sense now.Most of the weight of the slides is on the port side, or off door side. My tires are wearing on the starboard or door side which is the lighter side of the trailer. My thought was that if both sides of the axle had equal amounts of camber unloaded then loaded the two sides would wear differently. Therefore the port side is wearing perfectly but the starboard is wearing the outside edges of the tire. The camber should have been different on each side of trailer but that is apparently not how it was set up.
