laknox wrote:
After reading here about a guy who's kin pin is nearly 2" off-center, I'd be real careful about taking measurements from there, as it could lead to a false reading. I'd measure from the known centerline of the FRAME to the wheels. As others have said, there's quick and dirty methods of checking a gross misalignment, with the fist between the tires and string over the tires, being good ones. If any issues are found, I'd sure be contacting Jayco before I did =anything= else, including driving very far.
Lyle
IDK...On the kingpin off center subject isn't your kingpin position most important? It IS the point of attach to your TV of which the trailer axles should track straight in relation to. The trailer frame/box position is irrelevant... I believe measuring from the kingpin is still the correct approach and ^THIS^ guy really needs to now make sure his axles are aligned to his newly discovered off-center kingpin
Of all the methods described the plum bob off the kingpin is going to give the most accurate alignment numbers. Everything starts with the position of the front axle relative to the TV attach point
