rtate
May 29, 2014Explorer
Axle Alignment
Both tires on the door side of my trailer are showing are showing quite a bit of wear on the outside two inches. The tires on the other side are wearing perfectly. I have one small slide on the door ...
jrs1871 wrote:
Also take a level and measure each wheel vertically and horizontally. Again the measurements should be virtually equal. The vertical will probably be off of straight perpendicular but the difference on each of the wheels should be the same.
