Lar_sExplorerSep 18, 2015Axle AlignmentFriend of mine and I were crawling around underneath trying to see why water was dripping from the "cardboard" enclosure... guess it was the filter on the water pump that wasn't completely turned in.....Show More
bkickExplorerSep 19, 2015Since it is only one tire I would look to see if a bushing is worn as factory bushings are plastic. Had this happen to me.
Related ContentAxle Alignment.Axle alignment / correct trackAxle alignment after lift?Tires & AlignmentE-450 alignment!!!
