Lar_sExplorerSep 18, 2015Axle AlignmentFriend of mine and I were crawling around underneath trying to see why water was dripping from the "cardboard" enclosure... guess it was the filter on the water pump that wasn't completely turned in.....Show More
Mile_HighExplorerSep 19, 2015Mine was covered under warranty (old Keystone) along with 2 tires, but that changes with the temperature outside. Lose wheel bearings can cause it as well - worth a check.
Related ContentAxle Alignment.Axle alignment / correct trackAxle alignment after lift?Tires & AlignmentE-450 alignment!!!
