Friend of mine and I were crawling around underneath trying to see why water was dripping from the "cardboard" enclosure... guess it was the filter on the water pump that wasn't completely turned in.....
Easy to check parallel to the front axle with a tape measure. Within 1/4" is fine. Otherwise probably a bent axle or bad tire. Remove tire for proper inspection.
