MFL
Mar 06, 2019Nomad II
If your neighbors triple axle would not work, it is unlikely that a double axle will work, unless it is much shorter. Obviously towing nose high will make the problem worse also. A DRW will be less likely to tow the FW nose high. Was your neighbors rig level, on level ground?
Like mentioned, using planks at the appropriate time may help.
Jerry
Jerry
About Fifth Wheel Group
