Njmurvin
Mar 09, 2019Explorer II
MFL wrote:
Above is a good thing to keep in mind. On pavement, once rig is closer to straight, I shift to 4wd low, to take strain off from transmission, when backing uphill. This is even more important in a situation such as OP, that requires very slow uphill, stopping to check, restarting, and adding/removing boards, if needed.
Jerry
Excellent point!! I also use 4Lo to back up over a curb, over a horse trail and into my driveway to get a straight shot at my gate. Truck and trailer just slowly crawl along with virtually no resistance. Using 4Lo causes much less slippage of the torque converter thereby reducing heat. Same goes for backing into campsites where it takes multiple shots to get it right.
About Fifth Wheel Group
