greende
Apr 06, 2018Explorer II
I would use as much of your regular driveway and gravel pad as possible to do the "scoop" maneuver. I think you will do a better job backing. Also, can you pull out of your pad onto the access road to the left without your truck running over the neighbor's grass? If so, mark the path of the 5er wheels in chalk as you make the turn. Make note of how far down the road it takes for the trailer to straighten out. Now practice backing up following the chalk lines starting from that point.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 12, 2026
