thirtydaZe wrote:
A. Inside Corner
B. Inside
C. Not Sure
D. Out side
Essentially the road curves to the right, I will have to pass the pad and back in to my right. The shrubs are beyond the pad entry over grown on the right, and the drop off is on my left.
Someone mentioned the 'S', this actually seems, in theory to be an excellent plan, at least in my head it really seems to make sense.
If worst comes to worst, we will trade my inlaws pad for ours. they are just significantly shorter, which means i will have to park my vehicle elsewhere, which i'd rather not do.
I'm going to just go for our spot, if i can't get in, well, i can't get in. I need the practice with the larger RV anyhow, so it'll get done one way or the other.
I was hoping for tips, and i got a bunch as usual here.
Thanks again.
It looks like you have a SB, so watch 5er to cab clearance, longer 5er backs better than short.
You also likely have an auto, I have a manual, and would give it a try.
