Golden_HVAC
Jun 14, 2015Explorer
I just drilled a 3/8" hole through where I wanted to mount the camera, and ran the wire inside. From there, the sidewalls come down to the roof with a cover. I removed that cover, and could run the wire forward to my screen.
I also installed a couple of 12 volt cigarette lighter receptacles at the same time.
In your case, you probably need to run the wire forward to a point where you need to go into a closet, then down into the basement storage. Then to the front of the trailer, then to the truck itself.
Fred.
Fred.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
