So sorry for your problems OP... these are sortable issues so lets deal with them.
1) You need to trust your truck 100%. I'd rather have a v10 gasser than a 6.0 PSD if that is the motor you are running. Not throwing down on your particular truck.. this is just a terrible problem prone diesel motor. A boring but reliable gasser may be in order
2)The 12 volt problems could simply be a bad battery or power inverter or both
3) If your tires are ST tires I suggest replacing them with quality LT tires in the weight range you need
4) Were you being evicted from the campground? 24 more hours could have saved you some headache
Again, I am not trying to beat you up.. this situation stinks. The Fifth wheel is easily fixable with the little grimlins... You need to be 100% confident in your truck though.
If you have a 6.0 the head gaskets blowing are symptom.. if you don't fix the real problem then you could (will) blow another head gasket, especially if you have tuned it.
Thanks!
