Buckleup's avatar
Buckleup
Bath tub drain leaking
Bath tub drain leaks water into the basement and the dealer is a long way away, what can we use to seal it back up while on the road?
  • Thanks for the reply's, it is the drain at the tub its self. I sealed it with calk and we will see in the morning if it holds. Thanks again
  • And, it doesn't have to be YOUR dealer for repair, check if there is a local mobile service tech.
    Jim
  • When I got my first rv, the fittings weren't even hand-tight. Check them see things are built (slapped together) as fast as possible, and things like this often happen.
  • x2 Check the fittings from the basement.
    While loading some stuff in the bay I grabbed the P and the rings were loose.
  • Is it leaking at the trap or drain? If you have access, you may be able to just tighten the fitting(s).
    Robert
