BuckleupExplorerOct 14, 2013Bath tub drain leakingBath tub drain leaks water into the basement and the dealer is a long way away, what can we use to seal it back up while on the road?
100tonExplorerOct 14, 2013Is it leaking at the trap or drain? If you have access, you may be able to just tighten the fitting(s).Robert
