HaveHammerWillF
Oct 27, 2014Explorer
One item to think about is toxicity if the worst case scenario should happen (fire). While each form of insulation releases toxic fumes when burning, spray foam has been singled out as having the highest toxicity and flammability among the three. This article sums things up nicely.
http://www.treehugger.com/green-architecture/spray-foam-fires.html
If I was redoing a rig I would use a mix of the bat and spray, only applying the spray foam away from heat sources and not in low lying areas where the fumes could come up into the cabin if a fire occurred.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
