Coach-man
Jan 08, 2014Explorer
OK, first you know what your specific needs will be so get enough amp hours to comfortably handle those needs! Second, if any battery you buy has cold cranking amps listed (CCA's), they are not deep cycle and stay away from them! Last, in whatever set up you end up with, whether 1 battery or 12 batteries, if one goes bad you must replace all of them as the weak one will take out the new one, so keep that in mind when you budget for the batteries! Good luck, there are a lot of things you can do to be able to live comfortably in a dry camp situation!
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
