dave14117
Aug 31, 2017Explorer
Batteries not charging
05 Cougar fifth wheel, 2 year old Costco batteries.
Today tried to fix problem battery not charging when on AC power. Seems to charge ok when connected to truck; not sure. DC lights do brighten when on AC or truck, dim when no AC or truck.
I think the converter gets AC power, converts to 12v DC for the panel, and somehow also then sends 12v (@ ? amps) to charge the battery. So given that the lights brighten and its fan works, I think the converter must be getting AC power. But somehow the batteries aren’t being charged. Not sure if the charging ckt goes through the panel; if it does, all the fuses are ok, so maybe chewed wiring?
So far:
Checked auto fuses, all ok
Checked ground in basement and in panel area
Added water to batteries
Solution attempts
Removed TV/Stereo 12v fuse (disconnected it a month ago because it was making constant alarm; might still be drawing power)
Removed GFCI and replaced with regular outlet
Added tape to mice-chewed ground wire going from basement to panel
Any ideas appreciated
So far:
Solution attempts
