Executive wrote:
Asking for a friend. 2018 Solitude and the batteries stopped charging. He has four 6VDC battery bank with solar on the roof. He's hooked up to 50amp service. Checked all the normal stuff, GFCIs etc. Pedestal is solid so it's a coach gremlin. He woke up in the middle of the night to his alarm showing 11.4VDC on his battery bank. His rig has a Xantrex Freedom II inverter. I've checked all the fuses, breakers etc. and narrowed everything down to what appears to be a charging issue. I've read where there are two 'hidden' fuses behind the converter panel but I don't know where to look for those. Anyone have any thoughts.??? TIA...Dennis
Have a friend going thru this also, yes the friend has three fuses in his converter, not really hidden, but you need to get to the converter to check them , his are 30 amp. His fuses were okay, it appears his converter is bad, not getting the usual 13.5 or so out of it, its starts working okay then does not, and the battery gets run down. Friend is headed for a new converter.
