john_coach001's avatar
john_coach001
Explorer II
May 12, 2026
Solved
2003 newmar freightliner speedometer stopped working
Hello,
I’m looking for some advice. I recently purchased a 2003 Newmar motorhome built on a Freightliner chassis, and all of the gauges are not working.
The previous owner told me they all stopped working on the same day.
I have already replaced the VDC with a brand-new unit, so at this point it seems the issue may be related to the instrument cluster.
Does anyone have experience or knowledge with this type of motorhome?
  • My apologies. They told me they replaced the stepper motor inside the front air gauge and also repaired some bad solder joints inside the message center.
    That’s the information I was given, so I’m not exactly sure what was causing everything to stop working, but those are the repairs they said they performed. They also replaced both capacitors inside the message center.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      ok great.  some bad quality solder joints and some blowen capaciters, that will do it every time 🤣
      glade its all fixed up for you.  its rare to find a shop that will actualy get that involved, most would just replace the message center and charge you big bucks.
      • john_coach001's avatar
        john_coach001
        Explorer II
        The company that repair my cluster in the resolution above! I have share their contact.
  • might be a stupid question, but I assume all the fuses were checked.  and following that the wires inspected?
      john_coach001
      Explorer II
      Yes, I have checked all the fuses. I also verified the pins at the VDC connector and confirmed that I have 12V power, as well as approximately 7V on the wires going to the individual gauges.
      The turn signal and high beam indicators are displayed on the information center, but no other information is shown.
      At this point, I suspect there may be an issue with the instrument cluster/speedometer itself, but I’m not sure where I should start looking first.
