If you are going to run a decent sized inverter, you should go with the same gauge that your inverter requires. As stated, make the jumpers the same length and connect trailer load to one battery and ground to the other. I have a 2000 watt inverter and built my own 4/0 cables using welding cable purchased from Amazon. The welding cable bends very well.
