Butch50ExplorerSep 27, 2017Battery cable sizeI want to replace my single battery with 2 Grp 31 AGM deep cycle batteries. What size cable should I use to hook the batteries together? Thanks
jtbuildsExplorerSep 29, 2017I uses either Vertex or Ancor wire. This wire is temperature rated as well as being tinned so that over time it will no oxidize and loose capacity.
Related ContentBattery Size (replacing)Battery cable lug sizesDaisy chain cable size?What determines battery cable size?Battery Cable Sizing - PD9260
