deleted-2
Jul 04, 2013Explorer II
Does sound like a corroded or loose battery terminal connection or (as already stated) a loose ground wire on the main terminal block.
Might be a bad cell in the battery if the battery is only charging fully to 12.7
13.2 should be a full charge.
Pop the fill caps off the battery and look at those water levels.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
