I had similar issues, with stock disconect off, I could still raise and lower landing gear, move the slides, plus smoke and propane detectors! After two weeks sitting, battery was way down, had to put a external charger a couple of days before leaving to bring the battery back! Purchased a battery disconnect at Pep Boys, connects to negative terminal on the battery. With this on off position, two week storage battery only down a couple of 1/10's of a volt! I tried disconecting battery terminal, but this was a pain, you needed wrenches, etc, with disconect just a turn and you are ready to go! Easy and cheap solution to your problem!
