NC Hauler wrote:
B.O. Plenty wrote:
Nothing works when mine is turned off. I installed it myself. Nobody can move my front jacks if the power is off. I feel it adds a little security. I placed it inside the battery compartment which locks.
B.O.
B.O., Question:...IF your 5er is hooked to AC power, even though your battery is in by-pass, will the lights still work and can you move the slides or jacks...Mine does the same as yours when in by-pass and NOT plugged into shore power...( my by-pass mechanism is also locked to where you would really have to tear up stuff to get to it)..BUT, again, If I'm also hooked up to power, even if battery is in by-pass, I can still move slides and jacks.
Never tried it to see if the 12 volt works when plugged in with the battery switched off. No reason to. I have to turn the battery power on to get the convertor to charge my battery.
B.O.
