klassic
Sep 09, 2015Explorer
Battery isolator help
I was thinking of just using my two 6v batteries as "house" batteries for powering the residential fridge, TV's, lights..ect.
And having one 12v battery (because I already have it)to be the "starting" battery..powering just the slides and the leveling system (ground control 3.0)
Does anyone know if using a dual battery isolator will work with the coach's charging system?
The converter is a Progressive Dynamic with the charge wizard.
Will the charger sometimes see a low battery and stay at a "boost" voltage and eventually cook one of the isolated battery banks?
I want to do this because after running the batteries down (dry camping for a short time) there isn't much power left to operate the slides, and the ground control 3.0 needs to see a healthy voltage or it will error out.
If I have a separate battery it would be topped up for the brief high current use.
Thoughts?
Thoughts?
