Old-Biscuit
Jul 28, 2013Explorer III
Looking directly at the face of plug with tab on top......11:00 position is 12V DC Charge line
Looking at receptacle on truck slot at top......1:00 position
Check that you have 12V power at the trucks receptacle with truck on.
No power..check for fuse/relay in trucks fuse panel.....manual will should which position fuse/relay for towing should be.
Got power from receptacle....then check connections/power when trailer pigtail cord connects inside overhang of 5'vr.
Also those 'battery monitors'.......will always show full charge when connected to shore power.
Really need to check converter output and battery charge at battery
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
