Jim4929
Jul 28, 2013Explorer
Old-biscuit wrote:
Looking directly at the face of plug with tab on top......11:00 position is 12V DC Charge line
Check that you have 12V power at the trucks receptacle with truck on.
No power..check for fuse/relay in trucks fuse panel.....manual will should which position fuse/relay for towing should be.
I checked the TV fuse box and didn't see a fuse listed specificially for the 12v power. Someone in the campground had a tester and all showed good voltage except for the one shown with the 12v battery power per the diagram, so I'm pretty sure that is the problem. Right now I have brakes and lights and don't want to mess that up since I still have 2000 miles to go. I started taking off the connector but I could see I was getting in over my head and again I don't want to mess up what I have working now. Thanks for all the help
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
