wopachop wrote:
I was taught how the constant solar charge is not enough amps. The flooded batteries like that big beefy charge. Also the solar controller might not reach high enough voltage. I always forget. Don't we want 14.7 or 14.8? Your controller might allow you to choose a flooded option.
Modern MPPT solar controllers will provide
plenty of amps and volts to charge flooded batteries,
if the solar array is sized appropriately for the battery bank.
An occasional top off with a AC powered multi-step charger is still a good idea.
