4x4ord's avatar
4x4ord
Explorer III
Oct 10, 2020
Battery storage with solar
I was reading in Trojan’s literature that to properly store lead acid batteries It is best to monitor voltage or specific gravity and recharge batteries when they drop to 70% charge (12.37 volts). I could very easily switch my solar panels off and monitor the battery voltage with the intent to switch the panels back on at 12.37 volts to recharge the bank. Is this better than leaving the panels on 100% of the time? My charge controller will boost charge at 14.4 volts in the morning until the batteries are fully charged then switch to float charge (13.8 volts) for the remainder of the day. By morning the voltage drops to between 12.9 and 13 volts so the charge controller starts out charging at 14.4 volts again.
  • If your solar controller is a quality unit, let the controller maintain the batteries.
  • Continue doing want you are doing now. I have been doing the same as you for the last seven years expect my batteries get down to 85% charged in the morning before the sun comes out.
