TucsonJim
May 01, 2015Explorer II
clotus wrote:
I am assuming your landing gear power is cut with the switch as well. If this is the case, as is mine, I have to turn the battery on to hook it up, so I am not worried about forgetting that step.
^^^ X2 ^^^ If you have to turn on the switch to operate your landing gear, you won't have an issue.
And as others have mentioned, you should have a checklist you follow when you hook up. Make sure that is the first step.
About Fifth Wheel Group
