eronney's avatar
eronney
Battery tender on 5th Wheel
I would like to just hook up a battery tender on the batteries of my fifth wheel. I would not plug the fifth wheel in. Would the battery tender back feed and harm the converter-inverter.
I would just use the battery tender in the summer between uses instead of plugging the regular hook up.
  • If you have a battery shut off switch, that eliminates the need to isolate the batteries from the rest of the stuff you are powering up with the tender.
  • I will use the battery Tender maintainer sometimes instead of plugging the fifth wheel in.
    Thanks for the info.
  • RoyB's avatar
    RoyB
    Explorer II
    What ever battery tended you hook up will be feeding the 12VDC power distribution panel and other 12VDC items that connected.
    Just be sure not to connect the battery tender in reverse polarity otherwise you may blow some fuses...
    I have never really used a battery tender. Since you apparenty since you have 120VAC already available there I would probably plug the 30A SHore Power cable of the fifth wheel into your 120VAC source using a RV30A-15A long adapter and let the the fifth wheel on-board converter/charger unit keep your battery charged up for you.
    I have my trailer always plugged into the garage here at home in one of the 120VAC receptacles doing the same thing. We can run all of the lights and other things in the trailer including the air conditioner. Just cant run several high current things at the same time otherwise we end up tripping the garage circuit breaker.
    The only downside doing this is if your trailer does not have smart mode tchnology charging then you will want to keep tabs on the battery fluids. Applying 13.6VDC all the time may boil out your battery fluids over time.
    Even using your battery tender might do this as well...
    Just my thoughts
    Roy Ken
  • My FW is always connected to a battery tender when we are not using it.
  • Battery Tender brand battery charger/maintainer will work fine with all systems. No need to isolate while in use.
  • Assuming a battery 'tender' is a charger, no, it won't hurt anything.
