SailingOn
Aug 25, 2019Explorer
Dexter recommends inspecting the bearings once a year. You can't inspect the bearings without taking them off, so they get repacked.
We tow 6-10 thousand miles a year since 2011.
In that time, I've found, on separate occasions:
- brake wiring on one wheel worn bare by rubbing against the frame, easily corrected.
- pieces of brake lining bouncing around inside one hub; replaced the hub assembly.
- one bearing clearly scored; replaced.
Thousands of towing miles with confidence in the rig.
About Fifth Wheel Group
19,036 PostsLatest Activity: Apr 08, 2026
