Charlie_D_'s avatar
Charlie_D_
Bearings and Brakes-Last time
Frequently the question arises about bearing,brake inspection and lubrication and how often they should be done.
Over the years I have responded a few times but decided I would no longer read or comment yet I will break my silence this one last time and describe what I have seen last year and last week
I am a fanatic about maintenance and upkeep of all my vehicles and detest having someone else do it.
A year ago I decided to check the bearings. I found two of the four sets of bearings had spalled spots on the cup and outer rollers. New bearings and lip seals. Hand packed and reassembled. One year later, last week, I thought I would check the adjustment of the brakes as we are going on a 2 week trip this week. As I rotated the FIRST wheel I thought the normal rubbing that brakes do sounded a little different. I peeked into the adjustment hole and saw the 2 wires and knew something was not right. Upon removing the tire and bearings I found the tab that the magnet sits on had broken at the bend and the magnet, with broken wires, were sitting on the bottom of the drum. Thus no brakes. The broken piece had a jagged surface and it and the arm appeared to be wrought iron. The new arm appeared to be steel because it had a different finish and texture. All brake assemblies are the USA made Dexter. The brake assembly on the wheel next to it had done the same 1 year ago and upon inspection, being only 1 year old also had what appeared to be steel.The second and remaining 2 were in good condition. I am not a proponent of the EZ Lube system and if I were it would have not indicated the issues I found.
I am not trying to convince anyone from doing checks differently but it may cause them to think about it. Prior to 1 year ago and 14 years I had never found an issue. Two years ago upon advice on this forum I did buy a clamp on AC/DC meter to check brake voltage. I am in the habit of checking the voltage before trips to verify the system delivers the correct voltage and that the magnet energizes. Had I done this before jacking up the wheel I would have found that same magnet issue.
  • You are not "running off". I find comments like you just made as interesting as it gives me more information as to the type of people here and what is going on in there lives. Refreshing instead of the drama when posts such as I made or someone asks about brakes or electrical or sports. My good friend Bagman loves Ohio State and when he makes posts about them and their records it is not long before he is attacked,
    Get out there and enjoy and be safe. As time passes the opportunity to do so gets shorter every day.
  • RoyB's avatar
    RoyB
    Explorer III
    Charlie D. - I have been sitting here in Virginia for a couple of seasons now since I finally lost my BATTERY BANK... I'm just about ready to get a battery bank back on line for my OFF-ROAD camping... Of course just losing my battery bank is not a real good excuse for not going camping anymore - can add a single battery anytime... It has taken me a few years to come up with what I want now in my new battery bank and it is going to be real nice for me for camping off-trail as well as providing some back up power here at home. Kinda neat to plug in an extension cord to the off-road popup battery bank and run sometime for several hours haha...
    I am planning on doing a real good maintenance effort on my OFF-ROAD POPUP on the wheel bearings and inspection of everything connected to the hubs and Shocks etc... My last big maintenance a few years was to relocate the shock mounts so they would have a more vertical position for better operations. Had to have a new plate welded in place. My two shocks were almost at a horizontal position with the original layout... The last time I was laying under my trailer I really was thinking I need to change the whole suspension scheme out for something like this... This would eliminate the rear axle setup and give better off-road clearance...
    I don't foresee ever doing away with this 2008 OFF-ROAD camper... This type of suspension seems to be very popular with off-road campers down in Australia...
    Google image
    My State Inspection Sticker is way outdated now haha... It reads 9/11 hehe I drove on being suspended for a couple of years as I was not on any long road trips - just local camping here close to home...
    I am getting up in age now so probably will not make many more long trips with my OFF-ROAD popup but still want to get back to two or three of favorite camping spots here in Virginia... Definitely want to get back down to the Smoky Mtns again and North ALA/GA favorite camping spots... I have also missed a few of our remaining family get-to-gethers at Myrtle beach as well... Might want to get back to Wichita falls for a last look at things - Wife has family buried in Gober TX...
    here I am rattling on haha...
    Roy Ken
