chrizg
May 01, 2013Explorer
Been talked about many times over but the bed saver is not needed with the B&W. It is open or closed, no guess work. If you are just too busy with other stuff happening around you not to pay attention enough that you won't drop your expensive rig on your expensive truck then get a bed saver. The other hitches that you have to guess or can't see the hitch pin easy the bed saver is a no brainer.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
