Usnthedog's avatar
Usnthedog
Bed slide "flange" problems
The bed slide trim on my Greystone Re32 slide is flexing inward when the slide is out. Just looking at it it looks like the slide is a box and 1/2 plywood flanges were fastened to the box to keep it from falling out of the trailer. This seems to be a normal set up but my main slides seem to have some bracing and this does not. The trim is a 1x6 trim boards with separate corner blocks. The flanges have flexed so much that the blocks have came loose. It is all wrapped in rubber fabric so I can't see much. Does anyone know how this is put together? Is there a brace somewhere that keeps the flange solid or is it just nailed/screwed to the "box"? I'd send pictures if I could figure out how. Thanks, Jeff
It is a Heartland brand. Like a Sundance only Gray. Made only a couple of years.
  • Jeff,
    If you will follow these directions exactly, it is very easy to post pictures on our forums. One of our moderators, 1492, developed this photo posting app to post your pictures. It works for other internet sites also. There is no need to have a separate hosting site for your pictures in order to use it.
    It is very simple to use.
    1. Upload your picture from your computer to the app.
    2. Copy the resulting URL.
    3. Paste that URL into your post
    without ANY changes
    . No additions or deletions.
    Your picture will then appear in your post and be properly sized for use on our forums.:)
    Barney
  • I don't have a lot of experience with trailers, but pictures would probably help a lot, if you can post some.
