bookmaker's avatar
bookmaker
Slide Brake Problem
I have a 2010 Lance 1181. A couple weeks ago, prior to going out of town for a vacation, I attempted to retract the slide. It moved a couple inches then stopped. I changed the remote battery, tried the cable connect to the remote, plugged into shore power, all with no resolve.
I did notice the controller acted funny as the normal in and out buttons (left front jack) for the slide did nothing, but the button for the right front would cause a click that I assumed was a solenoid. Also, the ALL UP and ALL DOWN buttons just changed the unit from JACKS to SLIDE and back. I tried to use the manual crank and it would not budge.
The next morning, I decided to give the slide a little lift and shove while my wife tried the crank. Nothing. I decided to try the remote again. First I noted the buttons seemed to make the solenoid clicking using the right buttons. So I held the IN button and in it came. Also the other buttons worked as normal
Here is the real question. Why can't I get the override crank to work? I have flipped the Brake Switch to off, pulled the fuse at the motor, nothing works.
I am attaching a photo of the motor. There is a manual lever on it to engage and disengage the motor, but I have not been able to move the lever. Does anyone have this on their slide motor? If so, how do you move the lever. I don't want to use any force possibly braking something.
