filrupmark
Mar 08, 2016Explorer
Our bed has rollers mounted under it. But one roller is not positioned correctly . One corner of our bed was dragging slightly. I could not unscrew the roller without removing complete bed and frame.
I cut a block of wood the same thickness as the roller is tall for the bedframe to slide on . To keep the block positioned properly I ran some screws through the block protruding through the bottom of the block about 1/8" . They act as grippers in the carpet to keep the block from sliding around. Rub a little Ivory soap on top of the block for lubrication .
Works great. Easy and cheep fix
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
