WrightOn
Jul 28, 2018Explorer II
WrightOn wrote:
Update: I started with the most obvious - hydraulic fluid check and lubing the mechanism - but to no avail. Just before I broke down and called the dealer for an appointment, I decided to get the ladder out and give the slide topper a good check. A-ha! the slide topper was catching against the fiberglass and not allowing it to roll out properly. Somehow, a combination of a slight bend in the roller and a bow in the fiberglass eliminated the 1" clearance and created the drag.
I will combat this issue by taking out the screws that anchor the toppers to the slide (one by one since it is spring loaded) and placing a few stainless steel washers behind the bracket to create additional space.
I will post a picture of before and after in a week or two when I have time to work on it.
Here is the finished product. The five washers behind the ten screws (five per side) worked like a charm! It created the space needed for the slide to operate without dragging. Saved a trip to the dealer, and it cost me $18 plus 90 minutes of my time.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
