jonbarger
Aug 26, 2017Explorer
Bedroom slide
I have a 2010 41ft raptor toy hauler well I went to pull slides in and the bedroom didn't come in so I physically pushed it in well after further investigation it has pulled the mounting bolts from th...
jonbarger wrote:Almost all the work was done from the outside, but you still have to remove the bed framework to get to everything. When the slide was extended most of the floor was outside and not a big deal to get off.
Howard just one question how did you get the flooring out of it did you take the bottom off the slide from the outside and work at it that way are did you do all work from inside the camper
Thanks
