bcircus's avatar
bcircus
Bedroom TV no reception?
I have a 2011 Montana 5th wheel. First time camping in unit. We are in a campground hooked up to cable. Have TV in living room working fine. Hooked up to COACH cable inlet. I assume that means both TV's. Have tried to scan channels in Bedroom TV. Can not get anything on Bedroom TV. Have tried several times on every type of Cable type. I would think auto scan would fine any or all stations on the cable. I even went directly from another cable output directly to the Sat/Cable inlet for bedroom only. All wire seem to be hooked up. Even tried to use outside antenna on air setting. Still nothing. Is there something I am missing, switch? another cable? Any help would be appreciated.
  • Just a thought. My bedroom TV has a much better tuner than the main set. Same brand, different sizes and ages. The BR set gets half again as many OTA channels as the big one for any particular antenna heading.
  • Had same problem with mine factory forgot to connect coaxial to inlet . took storeage compartment panel down followed cable up connected ( Done).
