bcircus's avatar
bcircus
Bedroom TV no reception?
I have a 2011 Montana 5th wheel. First time camping in unit. We are in a campground hooked up to cable. Have TV in living room working fine. Hooked up to COACH cable inlet. I assume that means both TV's. Have tried to scan channels in Bedroom TV. Can not get anything on Bedroom TV. Have tried several times on every type of Cable type. I would think auto scan would fine any or all stations on the cable. I even went directly from another cable output directly to the Sat/Cable inlet for bedroom only. All wire seem to be hooked up. Even tried to use outside antenna on air setting. Still nothing. Is there something I am missing, switch? another cable? Any help would be appreciated.
  • Thank you, I have tried all of that. Have run through the menu and options several times.
  • Try the menu on the bedroom TV. Make sure the input is correct. Should be set to cable. If you have nothing hooked directly, the problem is most likely the TV. Input select the most likely cause.
