Greetings all. I got a new truck - and a new hitch - thanks to you all for your opinions. Hooked up the new hitch and the trailer and the world looked good - after some height adjustment. T...
If it were me, I wouldn't go any further until I knew the extent of the problem. It sounds very much like the frame is flexing and bending under the covering in the nose. Either broken welds, or broken frame. You should be able to remove the lower covering and see the issue. But much moving anywhere is going to make it worse.
