jodeb720
Dec 01, 2019Explorer
Bent Kingpin?
Greetings all. I got a new truck - and a new hitch - thanks to you all for your opinions. Hooked up the new hitch and the trailer and the world looked good - after some height adjustment. T...
schlep1967 wrote:
Like others have said, frame issue. Just a side note, it will help when explaining to others if you know the correct terminology. Your "Pin Box" is moving up into the front of the trailer. The "King Pin" is just the part that latches into the hitch. Good luck with the fix.
