It appears the award for "Best Hitch" has been given to the B&W Companion. I'm late to this thread (been camping), but I would like to nominate the Trailer Saver TS3 which I own.
- The Companion is made in USA, so is the Trailer Saver.
- The Companion uses heavy gauge steel, the TS3 is heavier, 1/4" plate with 3/4" solid steel risers.
- The Companion has thick jaws, those on the TS3 are thicker.
- The TS3 dissipates bouncing forces, the Companion doesn't.
- Due to the high hinge design, the TS3 dissipates chucking forces, the Companion doesn't.
- During panic braking, the TS3 causes the front of the trailer to push down loading the rear truck tires, a safety feature.
- The comfortable tow of the TS3 reduces driver fatigue, a safety feature.
- Shock mitigation of the TS3 protects the trailer's frame and the truck's electronics. The Companion doesn't do this.
The Companion is a good hitch, the TS3 just does so much more. In a "Best Hitch" competition, B&W would rank below Trailer Saver, Road master Comfort Ride, and Air Safe hitches. Due to the high prices, we just don't have as many fanboys.
