ESDA
Aug 22, 2022Explorer
Best Hitch
So I am looking at getting into a fifth wheel coming from a tow behind. On my trailer I have a Hensley and love it. I see that the also have the Trailersaver. Trying to find a good hitch that is ea...
cummins2014 wrote:MFL wrote:Cptnvideo wrote:
It is my understanding that it is NOT needed IF you have certain hitches AND if a visual check is done.
When you say certain hitches, yes, some are safer than others. The operator's understanding of their hitch, and ability to operate it correctly is still a factor. It appears you have a quality hitch, but I've never used your model.
I've a serious question for cummins2014, a forum friend, that I know uses an Andersen hitch. Do you need to do a pull test, with this ball type hitch, and different style coupler attached to king pin?
Jerry
Jerry ,not sure I want to answer that , I may have 12V come after me on that . :B But no there is no pull test on the Andersen ,nor has there ever been a discussion regarding the Andersen ,and a pull test that I know of . Although there has been plenty of other discussions regarding the Andersen . The one big thing is locking the adapter to the ball. I would not like find out if it could bounce off the ball. I have read where its been discovered being unlocked after travel, without issue.
I kinda get a feeling where this is leading , but its entirely different process hitching up an Andersen . Yes , it's all visual . It's lined up , and lowered on the ball, until the landing gear is raised off the ground . In my case with the six point leveling system they are raised all the way up . Then the handle is pushed in ,and locked . At that point it's hitched .
Let me point out ,because I have the feeling when you asked about a pull test ,and the possibly I am assuming you are thinking missing the ball entirely . Yes you could very well miss the ball, it would be tough on the newer Andersen's that have that red alignment cone. mine does not . In either case if you missed the ball ,you would be setting your fifth wheel on the bed rails of your truck, not a lot to stop it at that point . At some point in that process you would certainly know you are not on the ball. :)
