MFL
May 06, 2017Nomad II
lmpres wrote:
I had tried the block trick on my 5vr and it didn't raise it high enough to get the tire on the second axle off the ground. Maybe the trailer aid on top of the blocks might work. Curious, are those holes on the top for bolts to secure the black to the ramp?
While you may be able to use those holes for bolting to a block, they are quite large, and I think intended for carrying with two fingers, or hanging on wall.
Mine is a TA Plus, just a little taller. It has saw tooth grippers on the bottom to help control sliding.
Jerry
About Fifth Wheel Group
