Cummins12V98
May 06, 2017Explorer III
ford truck guy wrote:Cummins12V98 wrote:
With truck attached to RV this is a VERY safe way to work on one wheel at a time in your driveway or along the road.
You can't do it that way now can you ?.... The IS takes that out of the equation..
Or does placing the wood under it give you enough to make it work?
I still pack the TrailerAid with even tho I most likely won't need it since I now have 6 point leveling but conditions may require I need it. I would assume it would work as shown with the 2x block under it.
About Fifth Wheel Group
