travelrider73's avatar
Nov 15, 2013
Best of the best?
Which manufacturers would you all consider to be the BEST of the best in 5th Wheels?
We're looking for the comforts of home in a 5th wheel for full-timing. Four season, several slides, full size refrig, w/d, ideally a computer desk, all the hot water we want (tankless?), etc.
We'd also prefer manufacturers that have been around long enough that we can pick up a used model and save some money.
Thanks!
  • B.O. Plenty wrote:
    Continental Coach by Forks RV...Nothing else will come close. All custom built, you said you wanted the best. Should be able to get a nice one for about $500,000.
    If you want the best of the best they ain't cheap.
    B.O.
    OK, maybe not quite THAT best of the best... ha
  • Continental Coach by Forks RV...Nothing else will come close. All custom built, you said you wanted the best. Should be able to get a nice one for about $500,000.
    B.O.
  • drfife wrote:
    New Horizons, DRV and Excel would be great choices for full time use.
    Would be my list as well.
  • Dennis M M wrote:
    If you plan on going with one of those plan on a truck that can handle it - in most cases quality = weight
    Would that likely mean larger than a 1 ton Dually Diesel or would that suffice? My original hope was that a Chevy 3500 Diesel Crew Cab Long Bed would be perfect... But if I need to go bigger, I can. Nothing has been purchased yet.
  • New Horizons, DRV and Excel would be great choices for full time use.
  • New Horizons, Spacecraft, Teton, Newmar, not necessarily in that order.
