Y-Guy
Apr 18, 2016Moderator
I've used Tom Boles PDI Checklist on 3 RVs, worked well for me.
PDI & Other Checklists
Since most are not designed for Toy Haulers I suggest taking a full 5 gallon gas can, emptying into the tank and pumping it back out so you can text the fuel station as well as the generator. Test it under load not just firing it up. Turn the A/C units on and give it a good test.
Some dealers will squawk at the PDI. I had one dealer that didn't want me to do the PDI until I bought it, no way. I was ready to walk - he blinked. This should be one on your own time, you're not asking them to do the work. Ask they give you the initial orientation, then leave you be. Bring a clip board and have at it. Do not sign any purchase documents or loan docs until AFTER you complete your PDI and AFTER they fix anything that isn't working. They will be eager to fix these things before you buy it, but after then you have to go through warranty stuff.
About Fifth Wheel Group
